Alfa Giulia HYDRAULIC BRAKE SYSTEM - BLEED AIR
rickrd
Post by rickrd »
Hi, for the Alfa Romeo Giulia is there a fluid replacement and air bleed procedure on the ABS module? I can't find it.
Patata
Re: Alfa Giulia HYDRAULIC BRAKE SYSTEM - BLEED AIR
Post by Patata »
Any news? Antonela know how to bleed brakes in Giulia or Stelvio?
Regards
giulianoseguro
Post by giulianoseguro »
Hi fellas,
did anyone ever figure this out? need to do a brake bleed on my QV
Connect to the ABS Unit and then look at the Adjustments Tab - F7
giulianoseguro wrote: 29 Oct 2025, 14:05 Hi fellas,
you can always disconnect battery negative and do it manually old way using brake pedal.
