Data file corrupted multiecuscan
Posted: 13 Jun 2019, 19:54
Hello I have a problem with connection to Alfa Romeo Giulia 2.2 D. With other cars like 159, 147, some fiats etc everything works great but only with Giulia I won´t able to connect. I hit the button connect mes try to connect and than i see a message " conection failed data file corrupted check the port settings. I try to change comunication bitrate i try all possibilities of bitrate but nothing. I try cable ELM 327 also BT version both of them work fine with other cars but not with this. Has someone the same problem? Any ideas?
Thank You
Thank You
