trw2 airbag not showing
simon1968
Post by simon1968 »
there is no trw2 airbag interface showing for my alfa romeo 2.0ts spider. do i access it using the only option there? as it is the airbag system i am loathe to connect anything up until i know it wont set the airbags off
version 4.2
many thanks
Re: trw2 airbag not showing
See your car list here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
Note that you new the old style 3-Pin connector. This also means that the airbag is NOT on the EOBD socket but is on a separate 3 pin floating socket on a wire attached to the airbag control unit. The airbag control unit is probably mounted under the dashboard, in front of the gear lever on the central tunnel structure. The unit will have yellow cables going to it.
ppgl10
Post by ppgl10 »
hello, I have a fiat barchetta 95 and the latest free version of multiecuscan, cable kkl and. I can not connect with the ecu of the airbag or the engine. my car has a frontal airbag and 2 pretensioners. I do not know what to do to connect. Windows xp. Drivers?
