Can't connect via Bluetooth ELM327
Posted: 09 Jan 2019, 22:26
Hello!, thanks for reading.
Before creating this thread, I've searched the forum to see if there are other people with my issue.
I've found many threads about BT ELM327 connection issues, even talking about opening the connector to remove or add stuff...
But that's not my case, because the ELM327 adapter works perfectly with other software, such as ScanMaster-ELM on pc and Torque on Android.
So the adapter is fine, gives information and everything...
So it seems I'm not being able to use Multiecuscan, just this SW is giving me issues.
From all the other threads that I've read, none of them are conclusive or resolved.
Do I need to be registered to connect to modules that are marked as RED?
While in the configuration panels, if I search for interfaces (while the BT being paired to the adapter), it does not find any interface.
Also, the BT connection to the adapter breaks during this interface scan...
So I'm a bit lost here...
What I want to do is to change my service coupons value from 0 to 9 to re-enable services reminders...
Thank you!.
Thank you!.
