Fully working interfaces
Airidas36
Post by Airidas36 »
Hello everyone,
I am searching for an interface for my Fiat Stilo 2006 1.9JTD, that is supported in MES, and that I could connect to all modules (ofcourse except airbag and ABS, because they require additional adapters) and make adjustments, read data, delete faults. My chinese copy of ELM327 isn't working, and I want to get a working interface by not paying 100 euros + shipping :roll: . I've found this https://www.multiecuscan.it/en-us/elm-327-v-1.4-modificata-per-multiecuscan-con-software-free/
modified interface that is distributed by MES itself, so just to be sure I wanted to ask, will I be able to connect to most of the modules and make adjustments? If not, what are my other options?
Thanks in advance
Re: Fully working interfaces
See here: http://www.multiecuscan.net/Distributors.aspx
All these distributors are MultiECUScan recommended and supply proper fully working hardware. They will also offer support if you have problems.
Note that www.multiecuscan.it is one of the recommended.
So yes, in answer to your question www.multiecuscan.it is OK.
McLovin
Post by McLovin »
Which one have you bought, because i have a 2005 1.9 Multijet 88 Stilo?
I'm UK based so used GENDAN. I have KKL, ELM and OBDLink interfaces. OBDLink SX (USB cabled interface) is my preferred interface.
