renegade uconnect
gianco
renegade uconnect
Post by gianco »
hi!
i’m in italy
i have a jeep renegade my 2015,
with oem uconnect 6,5 and bests audio system( it has amplifier in trunk)
i want remove oem uconnect and install an aftermarket multimedia
(alpine x802d-u)
i have multiecuscan
my question is:
when i’ll remove the uconnect AND
rear amolifier,
how i’ll have to do proxy aligment?
what is the procedure to do?
the alpine comes with adapter to mantain all function also of steering wheel,
but ,
the can bus will flag an error for disconnecting rear amplifier?
Inviato da iPhone
Re: renegade uconnect
Before you change your head unit (uConnect to Alpine) I would VERY CAREFULLY AND IN DETAIL check that it supports ALL the vehicle settings that the uConnect supports.
When a uConnect is fitted to a vehicle during production, as oppsed to the simple radio, then many of the vehcle setup options (not radio/phone/media settings) are then done via uConnect and not the dashboard settings menu. Things like cornering lights, remote functions, etc.
gianco
Post by gianco »
understood
i now i’m evaluating another option
removal only of amplifier in the trunk,
non the uconnect
there is a unit from company “idatalink maestro ar”
that is made to substitute the oem amplifier with
another one aftermarket.
so the question:
if i leave oem uconnect, there are proxy alignement to do
removing only amplifier?
Toni2106
Post by Toni2106 »
Da quello che so amplificatore e in rete pero non dovrebbe darti nessuna problema
zimzia
Post by zimzia »
Hello, would it be possible to send proxi data ?, I want to add AMP to the radio
BR
gianco wrote: 24 Nov 2018, 15:19 hi!
i’m in italy
(alpine x802d-u)
i have multiecuscan
my question is:
rear amolifier,
but ,
Inviato da iPhone
chrener
Post by chrener »
there is possibility to change the car setup from uconnect to display between instrument cluster... You have to change your radio type in BCM... And setup menu will be automatically send from uConnect to IPC... You can do changes via steering wheel buttons after procedure...
