Unable to activate "Replacement of control unit and injectors"
Posted: 23 Nov 2018, 22:31
by gionag
Hello !
I was trying to reset the eeprom trims from injector due to an ecu and injectors swap.
The problem is with Alfa romeo - Brera 2.4 JTDM (EDC16C39)
tried both with KKL/VAGcom cable (fast timing) and ELM327 (wifi)
Dashboard on. Motor Off. Motor hot.
I went into the ecu module -> Adjustments -> Replacement of control units and injectors -> "Y".
After just a split of a second "EXECUTION FAILED" popped out.
just for curiosity i've also tested "Rail pressure sensor replacement"... same issue : "EXECUTION FAILED"
so i've tested all the other "REPLACEMENT...." related function and none of them are working.
I am able to activate "oil change" / "reset self-learnt function" ecc...
But all the "replacement" stuff is not working for me on this car.
Not tried on the other ECU neither on other car (i have only mine to test...)
Is that a normal behaviour ? i am not meeting some conditions to activate those tests ?
thanks for the support.
Michele
Posted: 02 Mar 2019, 22:10
by GeraldHiz
Im unable to browse this from home, I keep getting a http404 error. Works fine from work and I am trying them at the same time remote connection to home PC.
Do you restrict access to only 1 IP address?
