Need help connecting to 2015 Giulietta Body
stefy_hgs
Post by stefy_hgs »
Hello to all! I'm new to the forum, but not so new in the diagnostic job. I have my Multiecuscan multiplexed with CanTieCar interface for almost 2 years now, and I never had any problems, I'm quite happy with it, untill the other day, when a 2015 Giulietta came to the shop to add another key. The problem is that I can't connect to the body computer module, I alwaysget the "CanTieCar->ECU Connection failed! Check your cable and serial port settings" message. To the other modules I can connect with non problem and all the functions work as they're supposed to. As I know the CanTieCar doesn't need any other adapters as it's capable of switching the pins by it's own. Does anyone have any experience with this particularily module witch, theoretticaly is the same mounted on the new ducatos, or can shar some suggestions, I'll be greatfull. Thank you!
