Unhandled exception has occurred in your application
Anonymous375298
Post by Anonymous375298 »
I get this error eacth time a try to run the program. I have searched information and some say it is ralated to .NET Framework and that I have to istall an older version of it, the 3.5, but I have it installed and the error still happens. I'm using Windows 7. If you need any other information to help me let me know.
And this is all the code of the error:
Consulte el final de este mensaje para obtener más detalles sobre cómo invocar a la depuración
Just-In-Time (JIT) en lugar de a este cuadro de diálogo.
************** Texto de la excepción **************
System.FormatException: La cadena de entrada no tiene el formato correcto.
   en System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   en System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
   en System.Byte.Parse(String s, NumberStyles style, NumberFormatInfo info)
   en Multiecuscan.  .(String )
   en Multiecuscan.  .(String , String )
   en Multiecuscan. .()
   en Multiecuscan. . ()
   en Multiecuscan. . (Object , EventArgs )
   en System.Windows.Forms.Form.OnShown(EventArgs e)
   en System.Windows.Forms.Form.CallShownEvent()
   en System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
   en System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
   en System.Threading.ExecutionContext.runTryCode(Object userData)
   en System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   en System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
   en System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   en System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
   en System.Windows.Forms.Control.InvokeMarshaledCallbacks()
************** Ensamblados cargados **************
mscorlib
    Versión del ensamblado: 2.0.0.0
    Versión Win32: 2.0.50727.8798 (QFE.050727-8700)
    Código base: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Multiecuscan
    Versión del ensamblado: 4.2.0.0
    Versión Win32: 4.2.0.0
    Código base: file:///C:/Program%20Files/Multiecuscan/Multiecuscan.exe
System
    Versión Win32: 2.0.50727.8791 (QFE.050727-8700)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    Versión Win32: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    Versión Win32: 2.0.50727.5495 (Win7SP1GDR.050727-5400)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Windows.Forms.resources
    Versión Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
System.Xml
    Versión Win32: 2.0.50727.8773 (QFE.050727-8700)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
System.Management
    Versión Win32: 2.0.50727.8766 (QFE.050727-8700)
    Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** Depuración JIT **************
Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta
aplicación o equipo (machine.config) debe tener el
valor jitDebugging establecido en la sección system.windows.forms.
La aplicación también se debe compilar con la depuración
habilitada
Por ejemplo:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
Cuando esté habilitada la depuración JIT, cualquier excepción no controlada
se enviará al depurador JIT registrado en el equipo
en lugar de controlarlo mediante el cuadro de diálogo.
Re: Unhandled exception has occurred in your application
Suggest you contact MES Support directly with this issue and point them at this/your forum post.
Email: support AT multiECUscan DOT net
replace AT with @
replace DOR with .
Anonymous375298
s130 wrote: 27 Oct 2018, 17:58 Suggest you contact MES Support directly with this issue and point them at this/your forum post.
replace AT with @
replace DOR with .
Hi, I sent an email with the problem but I have not been replied.
Anyone know anything about this error?
