I've a problem with flashing odometer that i can't solve.
I've a Lancia Delta 2008, in which i removed the blue&me ECU and i replaced the original radio with a Kenwood double din. I also installed a Phonocar can interface in order to keep steering wheel controls and other signals needed. All it works fine, but the odometer is still flashing, even after the proxy alignement did with MES.
The procedure succesfully completed, and the odometer stop flashing, but at third key on restart flashing.
Has anyone solved a similar problem?
Odometer still flashing help please
HenryAboms
Re: Odometer still flashing help please
@ciano65 did you manage solve the odometer flashing? Was it from the Kenwood?
Sorry for being off topic.
I'm in the process of upgrading my stock stereo and looking for a good one.
From my research Kenwood is a good option. But can't make up my mind. All the reviews I've read so far are hype garbage. Actually I've tracked down a site that tells it how it is. I was eyeing the DDX9705S stereo thanks to the review. https://greatestspeakers.com/kenwood-ddx9705s-review/
Can you tell me how bad the screen glare is? What about the price is there enough value to justify it?
I'm open for suggestions
