hi
I fixed my fuel injector and got new IMA code. When I try to change the ima code in the engine's ecu everything is OK but when I go into the parameters tab I can see the old ima codes Why?
I have the full version of Multi ECU Scan a
In release 2.8 Ecu scan is the record-
,,Fixed IMA injector coding function for Grande Punto, Punto Evo, 500 and Mito,,
Can i try install 2.8 version ecu scan and run IMA code change in engine Ecu?What about the license ?When I re-install multiecuscan I will continue the full version?
Please help
Nissanek_3
nissanek_3
Re: IMA injector coding function for Grande Punto, Punto Evo, 500 and Mito
try using a KKL interface if you are using ELM
