Page 1 of 2
Will it support the old cars?
Posted: 03 Apr 2010, 16:35
by Pustynnikov
Hello, yani!
Thank you for the excellent program Multiecuscan!
But there is a question: will it support the old cars, such as Fiat Tipo / Tempra, which uses fuel injection Bosch MonoJetronic / MonoMotronic? Most necessary feature!
Re: Will it support the old cars?
Posted: 08 Apr 2010, 11:15
by alfa156sarajevo
I need this too...
Posted: 11 Apr 2010, 10:31
by Timmerklits
Yeah, that would be great.
It's also not that difficult, we just need to connect the white/red wire (K-line) of the 3 pin diagnostic connector (in the car), to the right pin on the OBD connector, and supply 12 v.
Now the same happens, only we just connect the OBD connector, + and - and K line are connected...
It would be great if all these cars are added.
I'm looking for diagnostic of the 155 q4 2.0 turbo, anyone knows where?
Posted: 17 Apr 2010, 08:18
by _-_pretender_-_
fiat coupe 20vt here... also a motronic... would be very usefull...
Posted: 20 Apr 2010, 10:11
by Zubrania
kappa's have the same engine. It would be really nice if you'll do support for the ecu
Posted: 21 Apr 2010, 11:07
by scsi
_-_pretender_-_ wrote:fiat coupe 20vt here... also a motronic... would be very usefull...
1. Use this
http://www.nailed-barnacle.co.uk/coupe/ ... rtrek.html
2. IMHO, I think that Jani will never do support older versions of ECU, since it is software aimed at obtaining commercial advantage, and focuses only on cars after 1997 model year(kwp2000 and later).
Posted: 21 Apr 2010, 12:02
by Zubrania
scsi wrote:_-_pretender_-_ wrote:fiat coupe 20vt here... also a motronic... would be very usefull...
1. Use this
Fiat and lancia use Motronic 2.10.4 which use KWP. So the main thing Yani needs - just a will to do the support
Posted: 21 Apr 2010, 15:57
by jony
Hí people
I am tested it =
http://www.nailed-barnacle.co.uk/coupe/ ... rtrek.html , but doesn´t work with all ECUs old , only iaw 16f .
Sorry , it Doesn´t work !!!!!
Some idea ?
Thanks.
Posted: 21 Apr 2010, 19:32
by jony
Hí , the program of Yani is very good , but , how to buy it ? , it doesn´t work for my car yet , sorry , sorry .
Thanks.
Posted: 26 Apr 2010, 08:27
by andrea
CIAO YANI IL TUO PROGRAMA E STUPENDO SON VERAMENTE SODDISFATO DEL LAVORO CHE AVVETE FATTO ...SAREI CONTENTO PERO SE UN DOMANI SI POTESSE DIAGNOSTICARE LE VECHIE IAW 6F 8F 16 F MONTATE SULLE VECCHIE PUNTO PANDA .IN FAMIGLIA NE ABBIAMO 4 QUINDI PROBLEMINI NE NASCONO DATO CHE VENGONO UTILIZZATE PER LAVORO...IN CAMPAGNIA .A PRESTO ANDREA.
