Fiat Panda 4x4 - 2014
Posted: 02 May 2018, 15:52
by Sophie IT
hello, i have the fiat Panda new model (2014)
The motor is twinair 0,9 turbo
I want to by Multiecuscan for reset maintenance notice
what version of the software do I need?
and what cables and interfaces do I need?
i'm confused..
where can I buy?
thanks for any help
Re: Fiat Panda 4x4 - 2014
Posted: 03 May 2018, 12:00
by Sophie IT
can anyone help me?
following the table for the Fiat Panda twinair 0,9 -2012
I understand that I need:
-ELM 327 v1.3+/OBDLink/OBDKey interface without adapter (unmodified)
-adattatore: A3 - ADAPTER CABLE 3 (yellow)
it's correct?
but I ask: where can I buy these original pieces? (I'm not interested non-original pieces)
thanks for the help
Sophie
Posted: 03 May 2018, 17:32
Please refer to this page
http://www.multiecuscan.net/Distributors.aspx
Find a distributer in your country.
These official distributers only supply kit that works and will give good support.
Going elsewhere may be cheaper but may also be troublesome.
Posted: 04 May 2018, 11:30
by davidino66
Posted: 04 May 2018, 13:03
by Sophie IT
thanks s130 and davidino for suggestions
ps:davidino you have a private messagge
Posted: 03 Jun 2018, 13:29
by Sophie IT
I tried the version 4.1 free and I saw that it connects to my panda
Now I want purchase registered version
I have two questions:
1) I can buy too multiecuscan.net (this site) or to have italian language I have to buy for italian rivenditor?
2) on my laptop, I often re-install the operating system (every 6 months) to have high-performance computers
(nb: I mean without changing hardware)
Every re-install system operation, Is it a problem for the license?
thanks
Sophie
Posted: 04 Jun 2018, 10:24
You can buy MES here on this website. MES allows you to change the language in the *licensed* version.
Regarding re-installing your operating system or changing hardware the please read the instructions in the MES User Manual. See
http://www.multiecuscan.net/HowToUse.aspx and click the "Download Manual" link. See Section 3 - "MultiECUScan License", Pages 10, 11 and 12.
Posted: 05 Jun 2018, 02:29
by Sophie IT
thanks
I have read user manual pag.10-11-12, but it is not clear
I do not change computer (or hardware..) when I re-install system operation
I re-install on the same Pc...then ID Hardware is always same
The manual saY:
[Please note that the License Transfer function has a limitation on the number of
transfers.]
but if I do not change Pc / hardware, is not correct that I have limitations for install Mes
ON THE SAME PC/HARDWARE!
thanks
Posted: 05 Jun 2018, 10:43
It is my understanding that if you are just re-installing the *same* OS version (eg Win 7) on the same hardware then you do not have to do a license transfer as the hardware key I believe is the same.
I only pointed you at those pages so you understand how the activation works. You should still make a note of all keys just in case. If you run into problems then MES Support will require the information from you (purchase info, key, etc.) to validate you as a licensed user and not somebody trying to obtain a free activation.
Posted: 05 Jun 2018, 23:07
by Sophie IT
thanks, ok I get it
I will convince my father to buy the license
