cannot connect
Posted: 07 Apr 2018, 18:56
Alfa Brera 2010 2.4
Tried to use fully registered multiecuscan ver 4 for first time using good elm3.27 interface adaptor v1.4.with ignition on, and cable connected to port. it will not connect.message is connection failed, check your cable and serial port settings.this i have done including interface settings and test. all is ok, but will not connect. cannot fault anything.
Someone please help need to do a proxy realign.
