Write Odometer Option
Posted: 17 Mar 2018, 18:53
by newresu
Hello, i can't find the "Write Odometer" Option under Adjustments,
i can see only "throttle position" for Fiat bravo 1.2 80hp
i'm using the free version. Ty
Re: Write Odometer Option
Posted: 18 Mar 2018, 14:22
Writing the odometer on your vehicle appears not to be supported. To verify check to see if the units listed you can connect to include DASHBOARD. This is where odometer writing would be supported.
Posted: 18 Mar 2018, 21:17
by newresu
How i can connect to include DASHBOARD ? i want to change the odometer to a higher value, Thanks.
Posted: 19 Mar 2018, 10:43
If the DASHBOARD node is not listed (with the Engine ECU, ABS, Airbag, etc) then MES does not support the dashboard and thus unable to adjust the odometer.
