Proxy alignment problem
Posted: 11 Mar 2018, 13:37
by tzzivii
I have an issue with proxy alignment. I changed the ecu and body computer with one from a uk donor after mine crashed and when i try to do the proxy alignment, in the dashboard node section it gives failed not supported by system error.
Any suggestions?
Re: Proxy alignment problem
Posted: 23 Mar 2018, 18:33
by tzzivii
Anyone?
Posted: 24 Mar 2018, 09:56
Do the procedure again and then use the Use the "Send Report" on the Main/Home Panel, bottom right next the MultiECUScan blue graphic. Then send an Email to MES support with some identification info so your Email and MES Report can be tied together.
