hi all, just getting to grips using this so i might ask some daft questions.
i have an alfa 155 v6, when you select ALFA, then you can select your car model. 145 147 etc. theres no 155 in there.
so can it be use multiecuscan on my 1996 v6.
thanks, maf.
ALFA 155 V6
Re: ALFA 155 V6
it has bosch motronic 1.7. which doesnt seem tp be listed.
Re: ALFA 155 V6
It uses kwp71 and most errors are the same for M2.10.4 in early 145/146 twinspark try those.
Re: ALFA 155 V6
ay up whizzman, fancy see`in you in here
cheers mate i will have try that.
