As from the title. (also sent a mail to the support address)
The adjustment doesn't work. So it fails.
Tried several times. Pc off and on again.
Car with only the instrument pannel on. Car with engine on.
I tried it in different situations but with always the same resut.
I use the ELM327. It works perfectly for other things.
The panel is a BASE. I'm sure about that because multiecuscan (3.7 verision) recognise it as BASE.
It connect also if I select the "Comfort" version but no results.
I can't deactivate the blinking seatbelts sound
The car is a Doblo 1.3 MJT (119 version) year 2005
