Alfa gt non start/can issues
Posted: 25 Apr 2017, 18:53
Alfa gt 1.9jtdm '07'
Faults:- non start', only the srs lamp illuminated (flickers) on dashboard/cluster, no other lights gauges work, no comms with cluster/srs/abs and sasn, done a scan with multiecuscan and showing
NBC=EOL OK, NCM=ok, NQS=EOL Failed, NFR=Removed, steering angle sensor (NAS=removed).
Fault code from NCM= U1706 CAN network (NCM-NFR). Have tried proxy realignment without success
Have removed body control module to isolate can bus and test, all appears to be ok, suspect bcm fault, is it possible to obtain a s/h bcm and program it with mscan, or are they program once only, or does anyone know of a company that test them.
