No Oil Pressure Reading
Posted: 18 Oct 2016, 10:10
by Greg Taylor
Hi, I have a 156 1.9 16v (140) mJet and a Registered copy of MultiECUScan
I had an Oil Pressure Low warning flash up a couple of times and have just connected the ECU up to have a look. No error messages were recorded for Oil Pressure. This was at start up and only lasted a second or two. It happened twice on the same day but not since
However, when I selected the Oil Pressure Parameter for display there was nothing displayed with either the engine stopped or running. Looking at the simulation setting it should be showing OK ( presumably a warning? )
Does anyone know if a nil display means a faulty sensor? It sort of fits the symptoms
many thanks
