1998 156 V6 Airbag reset problem
Posted: 13 Mar 2010, 17:23
Does this application not cover an Alfa Romeo 156 V6 ECU from 1998?
If I install the software, set up the com port, and modify the adaptor (bridging pin 3 to 7) I still cannot connect to turn of the light on the dashboard. I can connect to the ECU if I lie and tell the software I am connecting to a 2.0 Twinspark, and I can then turn actuators on and off and also read/clear fault codes. But I cannot access the airbag ECU, and I do not understand the difference between the choices listed between airbag ecu's?
Can you help?
Can you help?
