Internal Error-graph from other PC-decimal separator issue
epsonix
Post by epsonix »
Depends on MS Windows settings (usually home country preferences of PC user) decimal separator is either coma or dot. This is not handled right in MES - files from my PC (I use dot separator) are not exchangable with other users who use comma. Of course replacing in text editor all comas to dots helps, but that is not efficient solution. Could it be handled automatically or if not that there is some preference in Settings?
Re: Internal Error-graph from other PC-decimal separator iss
International language support, code pages, decimal "." vs "," separators are a real pain to code and test (I speak from limited experience :) )
tzok
Post by tzok »
This is a .NET app, so it is not a big deal...
public static double GetDouble(string value, double defaultValue)
    double result;
    //Try parsing in the current culture
    if (!double.TryParse(value, System.Globalization.NumberStyles.Any, CultureInfo.CurrentCulture, out result) &&
        //Then try in US english
        !double.TryParse(value, System.Globalization.NumberStyles.Any, CultureInfo.GetCultureInfo("en-US"), out result) &&
        //Then in neutral language
        !double.TryParse(value, System.Globalization.NumberStyles.Any, CultureInfo.InvariantCulture, out result))
        result = defaultValue;
    return result;
or
Double.Parse("3,5".Replace(',', '.'), CultureInfo.InvariantCulture);
... and voila! (this is not my code)
