fiat ecu scan cable
rasimyildirim
fiat ecu scan cable
Post by rasimyildirim »
good afternoon friends I got from fiat ecu scan cable on ebay. connects to the engine. ABS and airbag does not connect.
Re: fiat ecu scan cable
Read this page: http://www.multiecuscan.net/SupportedVehiclesList.aspx
You will see that different vehicle systems are connected to different EOBD pins. This means that you need a suitable modified cable or a set of adapter cables. Alternatively you need the expensive Mulitplexed system.
