Few days ago I try check my both lambda sond in my Punto II 1.2 16v (in MES it's '99 version) in engine module of course. My Punto is 2002 and I have two lambda sond.
I check few times, and I even try change language version, and there's no possibility to check voltage of 1st (Pre.-Cat.) lambda sond (oxygen sensor).
When I check in simlation mode Punto II 1.2 8v, there is both lambda sond to check voltage, but in 1.2 16v there's really mess on the list, and no 1st lambda sond to check.
There's only possibility to check heater or status od 1st lambda. Where's signal (voltage)?
On the 2nd (After-Cat.) there's: heater, status and signal (voltage).
Both lambda sond are the most fundamental thing to check when something goes wrong with the engine as you know.
Please, add the 1st lambda sond in the new MultiEcuScan in Fiat Punto II 1.2 16v.
Thanks.
