A Hello and request for help
Ethnic
Post by Ethnic »
Hi and hello from a total newbie.
Following advice received from the Fiat Forum, I have purchased a single licensed version of Multiecuscan and a interface from ebay - type ELM 327 v1.4 OBD2 CAN ECU MODIFIED for use with MULTI ECU SCAN multiecuscan (ebay ref 271275445368)
I have a Fiat Ducato 2.3 multijet euro 5 engine, manufactured late 2012.
When I connect and select Fiat Ducato (type 250) 2.3 multijet, i get error - check obd interface.
When I connect and selct Fiat Ducato (type 250) facelift 2.3 multijet, everything seems to work OK. Is this correct, as I thought the facelift model came out late 2014?
Also, If I want to resent the service interval, what connectors do I need and where can I get them from.
Thanks in advance
Nigel - a bit of a newbie
Re: A Hello and request for help
I would not worry about the facelift / no facelift. If facelift works then this is what you should be using.
If you read here:
and scroll to:
Fiat / Ducato (type 250) Facelift / 2.3 Multijet
you will find all the required connectors / pin connections / cables required.
For a complete cable set then look here:
https://www.gendan.co.uk/product_FESCBL.html
other UK sources may be available but I have no experience of them.
Somchai
Post by Somchai »
It is a new topic explains it well. Can be used as knowledge.
