Grande Punto Request
Posted: 11 Mar 2016, 01:35
Could you please add the option to change the type of ABS System (ABS to ESP) in body computer. (1.3 Multijet) Also to add steering angle calibration in the ABS adjustments. I have retrofitted a ESP Brake module and am getting C1213 - System configuration Incorrect control unit or calibration error.
I also had the P290F - Side Acceler./Yaw Node (NYL) error but mange to correct it by doing a Longitudinal acceleration signal learn in the gear box adjustments. I had to select the 1.4 8V Model and the CFC328 gearbox it gave an invalid ISO code but worked.
This option is not present on the 1.3 Multijet CFC300 gearbox.
When I turn on the key the abs light goes off and then after 7 seconds turns on and I get ABS, ESP, EBD, ASR, Hill holder unavailable error messages. During the time the lights are off the hill holder works. Sorry for the long post just trying to give you more information.
