Fiat 500 Twin Air - It just won't start
Rallyrob222
Post by Rallyrob222 »
Hi I have just baught a Fiat 2012 500c twinair with rear end damage there no air bags deployed. The problem is it wont start I have fuel pressure at the fuel regulator & spark at the plugs but after turning over the plugs are remaining DRY..Cleared all the error codes. Looking at the wireing diagram
the ignition packs and fuel injectors are feed by the same fuse. May not be getting a pulce from the E ECU but where next??
Would appreciate some help.
Rob,, :?: :?: :D
