Hello Yani:
May confirm when will be available support for ELM327 ???
When you add support for ELM327, that version and next of software, will not support VAG KKL cables anymore or will work with both VAG KKL and ELM327 ???
Please may confirm if K line with ELM327 also will need a switch to may connect to pins 1,3, 7, 9, 12 and 13 to access to different ECU's ????
CAN bus with ELM327 will work only by pins 6 and 14 to access to ALL ECU's or also will need some switch to connect with different pins - ECU's ???
Regards
About ELM327, CAN bus.
Re: About ELM327, CAN bus.
ELM 327 support will be available in next release.
It will support both VagCom/KKL and ELM327, and you will be able to connect to all currently supported ECUs with any of the supported interfaces.
ECUs connected on CAN network will only be accessible through the ELM327 interface.
... and, yes, you still need to connect 1-3-5-7-9 on your ELM327 interface to be able to connect to currently supported ECUs.
Thanks for your reply.
About Switch in ELM327, will need for K line and also for CAN bus, or CAN bus use pins 6 and 14 to access to all ECU's ??
With ELM327 I think cut pin7 to insert switch for K line, but do not know if CAN bus need also a switch.
Regards
Regards
Hi yani,
will the SW support other CAN Interfaces too? I have a PEAK-Can dongle from peak-system.com.
Thanks.
tomsa
Thanks.
tomsa
http://tomsa.bplaced.net
Only K-line needs to be connected to 1-3-7-9... CAN is always on pins 6 and 14.
@tomsa
Sorry, I don't have plans to support this interface now. Will think about it in the future.
@tomsa
Hi,yani wrote: ... and, yes, you still need to connect 1-3-5-7-9 on your ELM327 interface to be able to connect to currently supported ECUs.
Is the "5" a typo or should that be connected as well with the ELM327?
What does "5" do (airbag etc)?
Thank you for your time.
Sorry, it's a typo...
