mileage speedoreading Mito 1.3 JTDm 2011
tazio
Post by tazio »
I've while i reset the oilchange i changed also the mileage on the speedo reading with my stupid head from 90.000 km to 125.000 km.
I want to change it to the original 90.000 km but the system says it's only possible to change it in higher results.
Is it possible to got the 90.000 km back or have i an problem.
I hope there is an answer
Re: mileage speedoreading Mito 1.3 JTDm 2011
MES can only INCREASE the odometer reading!
Also settings the odometer to the maximum value hoping/thinking that it will next update to 0 and you can then set another value I believe dos not work.
I think you will have to find another program product to alter your odometer value backwards.
tazio wrote:I've while i reset the oil change i changed also the mileage on the speedo reading with my stupid head from 90.000 km to 125.000 km.
With MES or diagnostic equipment you can not do it.
You need special tool for that.
Or go to specialist or buy the tools. Cheapest tool cost more than 1400 EUR. It is better to go to specialist. :D
