Unclearable Code
Posted: 20 Aug 2015, 21:22
by dwnbyriver
Would it be possible for a function to be added, that could delete or disable a code from the ECU?
This would be useful where a fault has developed in the wiring loom, but will not harm the engine by doing so.
I have a P0480 code which cannot be cleared, yet the fan runs, and the engine maintains normal temperature.
I have seen adverts for software which can do this.
Re: Unclearable Code
Posted: 25 Aug 2015, 14:32
I don't think MES will be able to do this.
MES is not able to reprogram an ECU's executable code/map.
The normal ECU executable code, unless modified will detect and signal all faults found.
It may be that some ECUs have an "ignore" table that could possibly be updated??????
Posted: 28 Aug 2015, 11:05
by tzok
Have you testes all the fan speeds? Fan resistor is often the cause, and without one speed everything seems to work fine.
