Windscreen washer fluid level sensor
LukaCrc
Post by LukaCrc »
Hello everyone...
I am stuck at the windscreen washer fluid level sensor I want retrofit!!!... I found near the water container spare connector for the sensor. As far as I know the sensor is simple, just one signal, so logically when there is no signal message on the dashboard should come up, but when there IS signal(when water is in the sensor) everything is fine.. Now at the cable I found there is no signal of course. I tried to short circuit it, but nothing on the dashboard... Tried also in MES enable the headlight washer option, but no luck... I also checked the wiring, the wires comes all the way to the dashboard.. What seems to be a problem, does anyone know?? Thank you!
