URGENT! Set new Injector code not possible Alfa 159
eric
Post by eric »
car:
Alfa 159 QTronic 2,4
It is not possible to set the new Injector codes.
The software said all is successfull but the new codes are not stored.
Here the log:
ECU ISO Code: FD 86 BF 04 9B
21.02.2015 14:49:29
CONNECTED TO:
Alfa Romeo 159 2.4 JTDm 20V
Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9, 2.4)
ISO-Code: FD 86 BF 04 9B
FIAT-Zeichnngsnummer: 51883485
Hardware-Nummer: 0281012146
Hardware-Version: 00
Software-Nummer: 1037507414
Software-Version: 3841
Zulassungsnummer: 93952
Datum der Programmierung: 06/16/2010
LESE PARAMETER:
Code Einspritzdüse Zylinder 1:
LESE PARAMETER:
Code Einspritzdüse Zylinder 1: AR1WF6CAA
LESE PARAMETER:
LESE PARAMETER:
LESE PARAMETER:
LESE PARAMETER:
AUSFÜHREN EINSTELLUNG ...
Alter Wert: AR1WF6CAA
Neuer Wert: A81Z8X7AA
FERTIG
Attached also the log after restart the ignition.
FESLog_1502211454_Alfa Romeo 159 2.4 JTDm 20V.txt
(7.18 KiB) Downloaded 640 times
coolbits
Re: URGENT! Set new Injector code not possible Alfa 159
Post by coolbits »
Dont use ELM, it will not work. Try kkl cable.
eric
Post by eric »
Yep KKL was the final hint also from Yani via Mail. Working perfectly now.
