Interface Help for multiecuscan
RSMalta
Post by RSMalta »
Hi All
I am new to multiecuscan , i bought the registration for 1 computer and I had problems with the ELM27 Bluetooth not connecting
I want to get a usb wired one , I need to log engine parameters in order make checks for safety before and after remaps , and right now I need to log the following cars:
Fiat 500 Abarth 1.4 Turbo
Alfa Guiletta Quiadrofolie 1.8 Turbo
Which is the best interface for my use , and that can work on windows 8.1 64 bit
Will this be enough and does it work ?? http://www.ebay.co.uk/itm/271552892769? ... EBIDX%3AIT
Thanks for the help
Re: Interface Help for multiecuscan
hello RS-malta
Did this attention ??
Windows 8 note:
Multiecuscan works fine on Windows 8/8.1, but you have to install .NET Framework 3.5 (which is not installed by default). You simply have to go to Control Panel -> Add remove programs -> Add remove windows components, and install .NET Framework 3.5.
For the CANtieCAR interface you can install the same drivers as Windows 7.
Eddy is right. Check NET framework first...
This interface looks OK... ;)
