Help Making adjustments to the Headlight Washers?
Posted: 17 Jan 2015, 16:25
by Sweetaz
When I connect to 'Body computer Marelli' under the 'Body' system . I select Headlight washers under parameters and can see that they are switched off. Under Actuators I can execute the headlight washers and they proceed to squirt water at the head lights. However I cannot seem to find under any of the system menus of multiecuscan the option to enable them. Does anyone have any ideas? Many thanks.
Alfa 147 Selespeed.
Re: Help Making adjustments to the Headlight Washers?
Posted: 17 Jan 2015, 18:33
I think you are misunderstanding the parameters view.
Generally speaking the parameter view tells you the *current* state/value of the device.
If you connect again you will see the washes as being off. Now manually activate the washers and the parameter view for the washers should change to their current state. i.e. On/Running or what ever is the appropriate value for that washer parameter.
Nick
Posted: 18 Jan 2015, 00:23
by Sweetaz
Thanks for your reply. First day using the software today so trying to find my way around it. I purchased the software mainly for the PROXI align as I fitted a replacement climate control unit and the odometer was continually flashing. Managed to sort that today and also read the error that caused a 'Motor Control system Failure' to appear the other day. All in all a very useful tool.
It appears the head light washers only work when the lights are switched on, makes sense really. This could explain why I was having trouble getting my head around it.
Thanks again.
