Dura Hood 916 Spider
Posted: 13 Sep 2014, 14:41
by argtv6
Has anybody managed to connect to this module?
When I scan DTC with KL and purple connector from the the dash OBD connector only the engine ecu is seen.
When I scan DTC at the 3 pin connector in the battery compartment with or without the purple connector the Dura hood ecu is visible but impossible to connect to.
Please help
Ralph
Re: Dura Hood 916 Spider
Posted: 16 Sep 2014, 14:15
by alfa156sarajevo
I tried it on Brera and did worked without any problems.
Did not had chance to try on Spider...
Posted: 21 Oct 2014, 20:25
by argtv6
The 939 spider is completely different to the 916.
Thanks anyway.
Any ideas Yani?
I did send reports when failing to connect.
Ralph
Posted: 22 Oct 2014, 08:54
by alfa156sarajevo
argtv6 wrote:The 939 spider is completely different to the 916.
Thanks anyway.
Any ideas Yani?
Ralph
Did you tried it with new MES 2.2 version?
viewtopic.php?f=6&t=4308
Posted: 22 Oct 2014, 09:06
by yani
Yes, please try with Multiecuscan 2.2... and use the 3-pin connector.
Posted: 22 Oct 2014, 12:48
by argtv6
Hi.
I made this post before noticing that version 2.2 is out.
I'll try it out when I'll have another 916 spider at the workshop and revert.
Ralph
Posted: 01 Nov 2014, 21:24
by alfa156sarajevo
argtv6 wrote:Hi.
Ralph
Any infos?
Posted: 17 Nov 2014, 11:48
by argtv6
Hi.
I connected successfully from the 3pin connector in the battery compartment this morning.
I still have to get accustomed to the functions and parameters of this module as the commands I gave failed.
This particular car has a fault in the 5th bow sensors and some faults shown were without a description like 0F and 0D.
One confusing fault was regarding a deployed airbag.
Ralph
Posted: 09 Aug 2020, 10:30
by JvanEmmerik
I know this is an old post but I give it a try.
I've the same error (0D airbag). Hood not opening. Did you manage to fix it?
Kind regards,
Jan.
