Ducato X250, 2,3MJ 130 -07 problems
Posted: 15 Aug 2014, 06:03
by Jylppy
I have try to read codes from my Ducato. MES with ELM finds only engine ecu and abs ecu. With VAGCOM interface MES don't find any ecu's.
I use this ELM interface: http://www.ebay.com/itm/271566488992?ss ... 1497.l2649
I want to read airbag codes and dashboard. New dashboard not works correctly and airbag light is on some times.
Any suggestion or help??
And yes, I know, my english is very bad, sorry about that :-)
Re: Ducato X250, 2,3MJ 130 -07 problems
Posted: 15 Aug 2014, 07:09
Engine and ABS you can read
All other non-controllers?
right?
Then I guess that's your problem
viewtopic.php?f=5&t=1493
As is read when the airbag Multijet via CAN bus.
But it surprises me sell the merchant interface that should not be compatible with MES
Posted: 15 Aug 2014, 07:31
by Jylppy
I can read only engine and abs.
MES don't find any others controllers.
Seller says that this elm interface is modified for fiat....
How I can check that? Where to get right ELM?
Posted: 15 Aug 2014, 08:06
Hi there
Take a multimeter and measure the resistance between the
Pin 6 and pin 14 of the interface
Do you have an ohm value of approximately 120 ohms is not about
Posted: 15 Aug 2014, 09:03
by Jylppy
I just open the box, R04 are removed.
Ohm meter gives about 50kohm's.
Posted: 15 Aug 2014, 09:12
The value is OK
Which driver did you use?
On the enclosed CDs you can not use often.
If your interface identified in the Windows Control Panel without error?
times use this driver
Posted: 15 Aug 2014, 09:23
by Jylppy
I use drivers from sellers, 2.04.16.
www.idiagnostics.co.uk/drivers/elm.zip
I try to install newest drivers from ftdi but it not success.
They not install at all.
Interface is identified with 2.04.16 drivers without any errors.
And same result with XP and Vista laptops. Only these drivers are suitable.
Posted: 16 Aug 2014, 16:55
by Jylppy
I test with newest driver, both xp and vista laptops. Same result :-(
Drivers are installed without any errors.
