Page 1 of 3
Multiecuscan 2.0 released!
Posted: 06 Jun 2014, 17:40
by yani
I released Multiecuscan 2.0 today with the following changes:
- Small re-design of the user interface (also - better support for high-res displays, Disconnect button added on each screen)
- Added "CAN Monitor / Vehicle Settings" function which allows to monitor CAN traffic and to change the dashboard settings on vehicles with short menu (Bravo, Croma, Linea, Stilo, Panda, 147, 159, Brera, Spider, Delta, Thesis)
- Added support for Chrysler Ypsilon and Chrysler Delta
- Fixed connection problems with some Sedici modules
- Fixed the SCAN function to correctly identify Sedici modules
- Fixed connection problems with Giulietta ABS module
- Support for PROXI deactivation/activation of Mirrors with memory function (Stilo, Croma, 159)
- Support for PROXI deactivation/activation of Blue&Me/Radio functions
- Support for old TRW2 airbag (Spider, GTV, Barchetta, Coupe, 145) PLEASE BE VERY CAREFUL WITH THIS ONE!!! At least try to keep your head away from the airbags when connecting to it!
- Support for Diamond Active 4WD (Sedici)
- Support for Denso SUV climate control (Sedici)
- Support for Body Computer Calsonic Kansei SUV (Sedici)
- Support for Body Computer Calsonic Kansei SUV (E5) (Sedici)
- Support for SIEMENS Airbag (Sedici) (Full support)
- Support for Mitsubishi Electric Power Steering (Sedici) (Full support)
- Support for Bosch ABS (Sedici) (Full support)
- Support for TRW Airbag 2 (Ep - PROXI) (Ducato 250 Facelift, Panda 2011)
27/06/2014 EDIT:
I released Multiecuscan 2.0R1 to fix the Settings problem on 800x600 and 1024x600 screens.
Also, the installer now allows to install on removable drives, but the path has to be entered manually.
02/07/2014 EDIT:
I released Multiecuscan 2.0R2 to fix connection problems with Bluetooth interfaces.
Re: Multiecuscan 2.0 released!
Posted: 06 Jun 2014, 19:56
by us911
Thanks a lot :D :D :D
Uwe
Posted: 07 Jun 2014, 12:03
by Kinias
Where can I find CAN Monitor / Vehicle Settings ?
Posted: 07 Jun 2014, 13:24
by yani
Kinias wrote:Where can I find CAN Monitor / Vehicle Settings ?
What make/model is your car?
Posted: 07 Jun 2014, 17:16
by us911
I still can not read the airbag modul on my Panda 169 / 2012.
I have a "TRW (EP-Proxi) 3 in my panda.
Will there be an update soon?
Posted: 07 Jun 2014, 19:35
by tzok
There is a problem (at least for me) with this version - installer doesn't allow to install on a removable disk.
Posted: 08 Jun 2014, 16:51
by echappatte
No changes to start&stop proxy deactivation ? Problem of 1.9 (no start at all of the car) still the same ?
Thanks ;)
Posted: 08 Jun 2014, 18:44
by yani
us911 wrote:I still can not read the airbag modul on my Panda 169 / 2012.
Please try to connect with TRW Airbag 2 (Ep - PROXI) and send us a report (from the red Send Report button). Please also run the SCAN function to see if it will find it and send us a report again.
Posted: 08 Jun 2014, 18:48
by yani
echappatte wrote:No changes to start&stop proxy deactivation ? Problem of 1.9 (no start at all of the car) still the same ?
Thanks ;)
No, there is no change in this. As we discussed in other threads - it deactivates the S&S system in body computer, but that is not enough for disabling the whole S&S system.
Posted: 08 Jun 2014, 20:13
by us911
Hi Yani,
I have send you the 2 reports,as requested
and a 3rd one,without the yellow adapter,. just to show that the interface is ok.
Uwe
