CONNECTION PROBLEM
Posted: 01 Jun 2014, 18:02
by aerosmith
Hello, i have a problem with ECU connection on CROMA 2010 and YPSILON 1.3 MJT 75CV 2009. For example i can connect to the dashboard but when i try connection to ecu the software ask to verify eobd connection. What problem i have?
Thank you
Re: CONNECTION PROBLEM
Posted: 01 Jun 2014, 20:29
I guess by remote diagnosis that you are using the wrong driver.
install this driver
or the settings are not correct.
Posted: 01 Jun 2014, 23:10
by aerosmith
Thank you for your answer but i think that isn't a driver problem because with a grande punto 1.3 mjt i can connect to the ecu. Tomorrow i'll test with this driver and than i tell you what appened.
Regards
Posted: 27 Jun 2014, 09:26
by aerosmith
I've try but the drivers were the lastest. I can connect with VAG KKL cable, but i would to adjust my ELM.
Can anyone help me?
Posted: 27 Jun 2014, 18:45
Then you have to set in MES / Settings / Interfaces / on ELM
After that, you should also connect to the ELM can produce.
