Help with elm327 and Fiat ECU
Posted: 13 Feb 2014, 16:16
Hi!
I need some advice regarding the use of the ELM327 adapter with a FIAT Stilo Electric Power Steering (EPS).
I must connect with the EPS due to a project, and I'm connecting directly to the EPS (I only have the EPS) using the k-line.
When using the MultiECUScan software, i can connect without any problem (it recognizes the EPS and reads data).
But due to the project, I must communicate with the EPS using direct serial communication (for instance, using HyperTerminal). However, I tried lots of AT commands (including ATSP3 to use the k-line and "0100"), and i keep receiving only "BUS INIT: ERROR".
Can anyone help-me? What is the correct sequence of AT commands to connect to the EPS?
Thanks in advance, and sorry my English.
Rodrigo
Rodrigo
