Fiat Punto ECU
Hexore
Fiat Punto ECU
Post by Hexore »
Hi I have a Fiat Punto 1.2 16V 2001 188A5000:
I bought this cable "Click" http://www.scantool-direct.co.uk/multip ... -121-p.asp
but when I connect it to my car and do a scan only 2 things
ABS system and engine system no airbag what it might be.
I have tried to put the cable in all settings, if I run a latency test on the cable set to pin 3 I get time out
I also have a normal VAG KKL cable when I connect it and make a scan I get resutalt same as the cable with micro switc no airbag appears
Can it be the control unit for aribag there is damage
Sorry for my english
Regards Mikael
Re: Fiat Punto ECU
Hello Mikael
Have you asked your KKL on position 3?
If your airbag control unit supplied with 12 volts?
Hexore
Re: Fiat Punto ECU
Post by Hexore »
my system looks like this one in this youtube
http://www.youtube.com/watch?v=fOsNvNc_aaE
Dont think that i have to put some volts on airbag just have the car key set to on
im relly lost have try all
i have a ELM to its a ELM327 Ver1.5a i think its from china and cant get it to work
so i went back to get a ohter cable VAGKKL that on whit switc on top
info from scantool
Easy to use... No need to open and modify the interface, making it only suitable for one module
You do not need to use the coloured adapter cables, with this interface just select the appropriate pin number with the built in micro switch and diagnose the selected module
This cable and the MultiECUScan software will read and clear faults in the following modules.
Engine (Pin number 7)
ABS (Pin number 1)
Airbag (Pin number 3)
Climate control (Pin number 9)
Xenon headlights controller (Pin number 12)
TRW Type Electric Power steering (Pin number 9)
Gearbox (Pin number 7)
When using on 3 pin diagnostic connectors, set interface switch to pin number 7
My laptop wher i run ECU and FCU is a Acer 3Ghz 8Gb ram and windows 7 home
Re: Fiat Punto ECU
If you can connect to ABS and engine ECUs than you should connect to airbag ECU as well.
Have you chacked all settings in com port? Latency should be set at 1.
Maybe something is wrong with cable. Check connections from inside...
