Hi everyone!
My name is Piotr and I am new to the forum, I just bought Alfa Romeo 166 2.0 TS 2004 with faulty air con. I bought cables to find out what's the problem but I can't connect to Dashboard. I'm using KKL Interface with Green adaptor but multiecuscan won't connect. I got message:
Dashboard unknown/unsupported ISO Code: 32 83 85 19 A8 I can connect to engine, abs and airbags with no problems, I try all adaptors (red, yellow and green) Can't find any information abut this issue anywhere, could anybody help me? Thank you for your time.
Alfa Romeo 166 can't connect with dashboard
Re: Alfa Romeo 166 can't connect with dashboard
If you get message unknown/ unsupported that means your type in not supported.
Is it going to be supported in the future? Only Yani knows.
We can only sit and wait.
The only thing you can do is to keep trying and trying and trying to connect. I am sure eventually you will connect but from my experience connection last only 10 seconds and than system gets disconnected by itself.
I tested on few Alfas 166. If you can not connect with your KKL interface then try with ELM interface. If does not work with ELM then try manually to check installation, fuse and other things around air condition.
