License special deactivation
pierre06
Post by pierre06 »
Hi all
In january 2012, I purchased a license for MultiEcuScan 1.3 and I succesfully installed the software on a Dell Inspiron 8200
running with Windows XP. Unfortunately my Dell is now out of order.
I ve dropped off the hard drive in order to make it work as an USB external device.
I am wondering if there is a software (for windows 7) able to deactivate the license from the external USB hard drive in order to transfert
it on my new laptop.
Thank for your help
Re: License special deactivation
Simples thing to do is:
1) Install MES on new computer
2) Make a note of the Hardware Key
3) Send an email to support@multiecuscan.net with your original license data / purchase info
For reference the full transfer procedure information is given in the user manual as follows:
License Transfer functionality
In case you need to change or re-install your computer you can transfer the
license to the new system by using the License Transfer functionality of
Multiecuscan.
Here is how to use th e License Transfer function:
1. Open Multiecuscan on the computer where you have license.
2. Go to “Regist er” window and click “Deactivate” button
3. The system will generate a Removal Key (see the screenshot below)
4. Write down all 3 keys from the Register window – Hardware Key, License Key,
Removal Key.
5. Install Multiecuscan on the new computer.
6. Open Regist er window and write down the n ew Hardware Key.
7. Go to http: //www.multiecuscan. net/TransferLicense. aspx and enter the old data
(Hardware Key, License Key, Removal Key) and the new Hardware Key and your
email and click “Request License”.
8. You will receive an email with the new License Key.
If you have any problems with the License Transfer function you can send us an
email with the new Hardware Key to support @multiecuscan.net.
