Page 1 of 2
Multiecuscan 1.7 RELEASED!
Posted: 11 Sep 2013, 12:41
by yani
I released Multiecuscan 1.7 today with the following changes:
- Support for PROXI deactivation/activation of Hazzard lights on hard braking function (Grande Punto, Evo, 500, Mito, Giulietta) (Thanks to @Mazza-Engineering)
- Support for PROXI deactivation/activation of factory alarm function (Stilo, 159)
- Support for Continental MK60EC ABS (Doblo, Giulietta) (Full support)
- Support for Marelli Suspension control (Mito)
- Support for FUJI SG-CVT Automatic Gearbox (Punto '99, Palio)
- Support for Bosch EDC16C39 CF4/EOBD Diesel Injection (1.9 8V) (Outside EU) (Grande Punto)
- Support for Magneti Marelli IAW 5SF3 CF4/EOBD Injection (8V) (Outside EU) (Grande Punto)
- Support for Magneti Marelli IAW 5SF CF4/EOBD Injection (1.4 8V) (Outside EU) (Doblo, Palio)
- Support for Bosch Motronic MED7.11 EOBD Injection (Outside EU) (156)
- Support for Bosch Motronic ME 3.1 EOBD (3.0 V6) (Outside EU) (156, 166, GTV, Spider)
- Support for Bosch Motronic ME 3.1 EOBD (2.0, 2.4) (Outside EU) (Stilo, Marea, Libra)
- Support for Bosch Motronic ME7.3H4 EOBD Injection (Outside EU) (Punto '99, Palio)
Re: Multiecuscan 1.7 RELEASED!
Posted: 11 Sep 2013, 14:28
by alpha
Thanks Yani
I still cannot register the new version ??
I sent you a PM regarding this problem last month.
Posted: 13 Sep 2013, 21:57
by Mazza-Engineering
Thanks to Yani for cooperation.
I only found out the bit, he did the rest
Posted: 14 Sep 2013, 00:32
by jony
Ok Yani , great job.
In next release, any support to old ECU engines IAW-marelli ?
many thanks.
Posted: 14 Sep 2013, 17:48
by alfa156sarajevo
jony wrote:Ok Yani , great job.
many thanks.
Try this software:
http://iaw-scan2.sourceforge.net/
It is working with old IAW ECUs... MES member named
tzok is creator of that software... It is free and it is good...
Posted: 05 Oct 2013, 09:23
by alex2trois
I live in France I'm an electrician, your site is very good but I do not speak English, I use Google translation each time ...
Here is my problem:
I bought a Fiat Ducato 2.2 Multijet 100cv the airbag light stays on
is there a proximal alignment for this type of vehicle? I bought on your site multiécuscan 1.7 but I can not find "alignment proximal"
I had the bad idea to do a proximal alignment from Fiat doblo on my ducato is that it's serious?
can we go back?
if you're interested I have my bin file crash
Thank you good day
Bonjour,
J'habite en France je suis électricien, votre site est très bien mais je ne parle pas Anglais, j'utilise Google traduction à chaque fois...
Voici mon problème :
J'ai acheté un Fiat ducato 2.2 multijet 100cv le voyant airbag reste allumé
est ce qu'il existe un alignment proxi pour ce type de véhicule ? j'ai acheté sur votre site multiécuscan 1.7 mais je ne trouve pas "alignment proxi"
j'ai eu la mauvaise idée de faire un alignment proxi a partir du Fiat doblo sur mon ducato est ce que c 'est grave ?
peut on revenir en arriere ?
si ça vous intéresse j'ai mon fichier bin crash
Merci bonne journée
Posted: 09 Oct 2013, 21:08
by alfa156sarajevo
@alex2trois
Proxy alignment is used for example when you change dashboard and you have blinking display than you use proxy.
There is no need to do proxy when you repairing airbag system. You can do it but there is nothing that will make it better.
It will be same if you did not do proxy.
You need to read crash data from the airbag unit, post crash dump here with details of airbag ecu and I will try to help you.
Posted: 15 Oct 2013, 21:32
by alex2trois
Thank you for answer
as I told you I had a proximal alignment on my ducato but as there is not this parameter to my car I used the alignment doblo
therefore I have no hands on the activation or deactivation of the passenger from the dashboard airbag although it does not exist on my version, but I remember at the beginning there was the possibility it may be why my light stays on
I will anyway try to post my files bin crash before and after repair reading eprome with MiniPro tantative program and repair airbag universal repair v2
how to post a file I do not know how
Bonjour,
Merci de m'avoir répondu
comme je vous l'ai dit j'ai fait un alignement proxi sur mon ducato mais comme il n'y a pas ce paramétre pour mon véhicule j'ai utilisé l'alignement pour doblo
de ce fait je n'ai plus la main sur l'activation ou la désactivation de l'airbag passager à partir du tableau de bord bien qu'il n'existe pas sur ma version mais je me souviens au début il y avait cette possibilité c'est peut etre pour cela que mon voyant reste allumé
je vais quand meme essayer de poster mes fichiers bin crash avant et apres réparation lecture de l'eprome avec minipro programmer et tantative de reparation avec airbag universal repair v2
Posted: 18 Oct 2013, 20:39
by alfa156sarajevo
When you save the bin file you can try to upload it directly here.
If does not work directly you can put that bin file in new folder and than make zip file from that folder.
Below under reply box you have option "Upload attachment".
Just select your file and that is it...
Posted: 19 Oct 2013, 10:09
by Pdm
Yani, too bad that mes 1.7 can't adjust uniair dispersion on my Alfa MiTo 1.4 multiair 105 cv (Magneti Marelli). I'll try to downgrade to mes 1.3 again...
