Fiat linea can't access
Posted: 12 Jul 2013, 15:12
by yoko
I have a fiat linea 1.4 t-jet engine
i can't access the car at all Can info
and when i scan the car it shows engine only!!!
if i bought a full version will be my car fully suported ?
Re: Fiat linea can't access
Posted: 13 Jul 2013, 07:39
We Linea at your motor control, ABS read more about the protocol KWP2000. For the ABS you need an adapter 1 (green)
The other controls are read via CAN bus, plus you need an ELM interface!
Do you use an ELM?
With the free version Multiecuscan should at least be found all controls.
If so, then read times on here
viewtopic.php?f=5&t=1493
Posted: 13 Jul 2013, 13:17
by yoko
yes i am using an ELM
it is probably the resistor problem
Posted: 13 Jul 2013, 14:19
Hello Yoko
If the bridge resistor is the problem, you have enough information that can help you in the linked post.
