can you reset the overev count parameters?
Posted: 04 Jul 2013, 12:03
by crimson96
I have a 159 3.2 JTS ti 2008 - is it possible to reset any of the parameters in the ECU module - particularly the following:
- Overrev count
- Max. Engine speed time
- Maximum RPM operation
Or any of the parameters in the engine module.
Re: can you reset the overev count parameters?
Posted: 07 Jul 2013, 15:09
by alfa156sarajevo
You can only do "reset of motor self-adaptive parameters".
"This function allows to set to zero all the motor self-adaptive parameters. WARNING: after zeroing the self-adaptive parameters remember to carry out the climate control learn procedure (key on MAR with climate control on for 1 minute)."
Beside that you can read/ delete errors, see parameters and do some actuators tests...
Posted: 07 Jul 2013, 15:12
by alfa156sarajevo
Easiest way foe you is to install MES and click on simulate button.
There you can find all information what MES can do...
