kris wrote:I got the speedo meter working. The problem was that I had a panel from a 1.3 mjet in my 1.4 8v. I thought that it would work.
But still proxi doesnt work properly. I though that after the proxi alignment, the correct mileage would be written. But the proxi procedure just took the highest mileage (of the instrument panel). If I connect with mes to the motor section, the mileage says 68000. And if I connect with the instrument panel, the mileage says 95000. The instrument panel also shows 95000.
Yani can you please fix the proxi alignment in an update, so that it takes the right value. Did the proxi alignment went ok? The mileage isn't blinking, so how did it took the wrong mileage.
I do not think Yani can do anything about that with MES.
Mileage is stored in 2 different places in instrument panel and in engine ecu.
Both of them working separately.
What you need to do is change mileage in your dashboard and everything will work just fine.
