hi
what is the difference between the "Fiat Multipla '02 Van 1.9 JTD/Multijet" and the non VAN type - "Fiat Multipla '02 1.9 JTD/Multijet"
how do i tell which multipla i have?
my car is 1.9 JTD 2002 and there are 3 variants that comply,
"Fiat Multipla 1.9 JTD"
BR
fiat multipla 02' JTD variants question
Re: fiat multipla 02' JTD variants question
To be 100% sure which is one you have 2 options:
1. Open MES. Connect cable from laptop to car. Turn ignition (MAR position). Do the scan (F11).
After scan is complete you will see which one is the model that you need for your car.
2. Open MES. Connect cable from laptop to car. Turn ignition (MAR position).
Try to select first option (for example Fiat Multipla 1.9 JTD).
If you got message where it shows that you have “wrong ISO code”, disconnect MES.
Try to connect with next model on the list. You can try all models. One should work.
Like this you can not damage or your car or MES or interface or laptop.
Sometimes you can connect even if you have “wrong ISO code” message.
Maybe you will not be able to read all parameters but you can do it. You can not make any damage.
