TRA and FRA self adaptive
Posted: 30 Apr 2013, 18:08
by atgsh
What that is the mean of TRA and FRA self adaptive parameters
I have TRA 80 and FRA - 8
I try to adjust my LPG
Re: TRA and FRA self adaptive
Posted: 10 May 2013, 18:40
by Boris
atgsh wrote:What that is the mean of TRA and FRA self adaptive parameters
This parameters are long and short term fuel trims. Basically these are fuel corections (in a long term, and a temporary ones) done by ECU in order to achive 14.7 fuel stochiometric mixture (lambda factor 1) using oxygen sensor (lambda sensor). You can find more explanations on the net
AFAIK fuel trims errors are often problem on LPG conversions.
TRA 80 an FRA -8 does not sound OK
Posted: 13 May 2013, 20:50
by oem
You have rich mixtures on lpg. The best choice is reset adaptation. Driving on petrol for 10 km at part throttle (up to 80% throttle). Working at idle for 15 min on >80C engine temperature.
Look adaptation values and then adjust lpg with keep the same values.
