Simulate Mode for ECUs requiring 3 pin adaptor
Hi Yani
Simple bug that I've just noticed.
If you try to CTRL/F10 (Simulate) to an ECU that requires a 3-Pin adapter then you get the prompt to "Connect 3-Pin Adapter" which one accepts with a Yes/Y OK. Then the program actually goes to the Connecting to ECU phase followed by "Connection Failed - You need KKL adaptor........" instead of the normal "Invalid ISO Code" msg/prompt.
For simulation mode no adaptor test/connection should be made.
Nick
Juggers2k
Re: Simulate Mode for ECUs requiring 3 pin adaptor
Post by Juggers2k »
For simulation mode to work, the interface type required by a module (e.g. ELM327 or KKL) has to be configured in the software (even if it's not actually plugged in).
It sounds like you were connecting to a module which requires the KKL for connection, but maybe only had the ELM configured?
I guess it just brings up the adaptor cable prompts before it does the interface check...
HASSAN
Post by HASSAN »
Juggers2k wrote:For simulation mode to work, the interface type required by a module (e.g. ELM327 or KKL) has to be configured in the software (even if it's not actually plugged in).
HI
today try to connect to ecu fiat marea year 1999 no succes i use adapter 3pin
with vag interce registerd
any help thanks
