Hi all.
I cant connect ECU SCAN to my PUNTO 1,2 16V YEAR 2002.IT says that i need a registred version.
My cable is a basis KL /vagcom What can i do.
Best regards.Tommyk
FIAT PUNTO
Re: FIAT PUNTO
Produce on the Motronic ME 7.3H4 Can you only with the registered version of Multiecuscan connect
Purchase you read the Registering (50 €) and you can use your ECU
Re: FIAT PUNTO
According to Supported Vehicles List web page: http://www.multiecuscan.net/SupportedVehiclesList.aspx
if you would like to connect to your Punto 1.2 16V you need a registered version of MES.
So you have few options:
- you can buy license version of MES
- you can try to connect to your engine ecu with some other/ similar engine ecu (I am not 100% sure it will work)
- or you can find older vesion of MES/ FES on the web somewhere and try to connect to your ecu (I am not 100% sure it will work or is it supported)
